hi,
my starter on my 1991 lincoln seems not to be operating correctly. i tried starting my car and the starter made a whining noise and did not turn the crank. i took the starter out to test it by hooking battery jumper cables up to it. i grounded the starter with the negative cable and put the positive jumper cable on the small connector on the solinoid. the starter plunged outward with the cog on the end but the cog would not turn. is the starter bad or just the motor, but solinoid still good. or does the cog not turn because it is not suppose to?..thanks
Mar 23, 2010 at 1:07 AM
