Cost will depend on what damage is done, the head may be cracked or warped the cost will be unknown until it is inspected, you may be able to get a quote for a change over reco head, you will have to price this in your local area as I am in Australia I have no prices, most work shops will be able to quote over the phone on a change over head supplied and fitted. as for the cause, you may have had a coolant leak a faulty radiator or thermostat often an over heating event will cause a problem like this, also not using correct coolant can cause the head to corrode and cause a problem over a long time.
Mar 8, 2015 at 11:13 AM
