[quote:8f0d3e4d87="nicknice21"]Engine problem
1992 Lincoln Town Car V8 Two Wheel Drive Automatic 161100 miles
What does it mean when my check engine light comes on after I drive the car approximately 20 to 30 minutes?
I had the following services done to my vehicle:
* Regular oil changed (Use Lucas Oil products)
* Front shock absorbers replaced
* Alternator replaced
* Fuel pump, filter, strainer replaced[/quote:8f0d3e4d87]
most check engine lights on is related to an emission
or sensor fault
you can put best oil in the car and best gas and have the regular maintenance done on it
its not going to change if you have a bad sensor
or wire
my suggestion : have it scanned for code s that will pin point the trouble area for you
you can post the codes for more help if you like
good luck
Feb 4, 2019 at 10:15 AM
(Merged)
