1990 Lincoln Town Car Stalling Car
JKROLL
1990 Lincoln Town Car Automatic
I have cut the cats off because they were glowing red and my car was stalling. Aftr that it ran sorta ok until it was low on fuel and continued to stall. I was advised it may be the o2 sencors or the fuel pump. So, I replaced the fuel pump. I put in a 1/2 a tank of gas and it ran great until I got low on fuel and again it stalled. I cant keep replacing everything, as it is becoming very costly. Please advise if you might know what I need to do next to make the car run without stalling.
Jun 29, 2008 at 12:47 PM
  • 75,988 POSTS
Did you replace the fuel filter and when you changed out the fuel pump did you check the in tank fuel strainer for debris
Jun 29, 2008 at 12:59 PM
JKROLL
yes tank was clean and filter new
Jun 29, 2008 at 1:30 PM
  • 75,988 POSTS
Perfom another fuel pressure check that's with and w/o the fuel pressure regulator and comeback with the readings we go from here-also check the available voltage on the fuel pump connector
Jun 29, 2008 at 2:54 PM
