1990 Lincoln Town Car help me
106,000 MILES • V8 • 2WD • AUTOMATIC
KIEFER84
i put a new fuel pump in and fuel pump relay and my car still wont start whats wrong with it
Jul 10, 2008 at 3:46 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:cd9fe78723="kiefer84"]Engine Mechanical problem
1990 Lincoln Town Car V8 Two Wheel Drive Automatic 106000 miles
i put a new fuel pump in and fuel pump relay and my car still wont start whats wrong with it[/quote:cd9fe78723]
Have you check to see if you have fire at the Spark Plugs? If not check and see if you have spark going into the cap.
Jul 11, 2008 at 1:02 AM
DJFINESSE80
  • 34 POSTS
IF U HAVE DISTR CAP, REMOVE AND START IGNITION, IF THE ROTOR DOESNT TURN, REMOVE #1 PLUG, TWIST A PAPER TOWEL INTO PLUG OPENING(JUST SLIGHTLY)TURNKEY, IF P TOWEL DOESNT POP OUT FROM COMPRESSION? TIMING CHAIN!IF IT DOES, CHECK DISTRIB ROTOR HOUSING AND REPLACE.PUT AT TOP DEAD CENTR, AND PUT ROTOR at #1 CYLYDER, AND IT SHOULD SLIDE INTO PLACE, IF NOT ,INTERNAL DISTRIB GEARS ARE BAD(REPLACE ENGINE)
https://images.2carpros.com/forum/automotive_pictures/218559_m_bfac118db97d5095beff1f53f16e3594_10.jpg
Jul 29, 2008 at 10:46 PM
