1990 Lincoln Town Car Fuel Pump
1990 LINCOLN TOWN CAR
120,000 MILES • V8 • 2WD • AUTOMATIC
HEATHER BURNETT
The is turning over but won't start. We checked the fuses and the fuel pump fuse was blown. When we put a different fuse in and tried to start the vehicle the fuse blew again. When you try to start you can smell a faint hint of gas. What should we look at. Not sure if the Fuel pump or ecc relays are blown.
Jun 25, 2010 at 4:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
replace fuel filter.. also check the wiring to the fuel pump, may have bare spot somewhere causing short and blowing the fuse.
Jun 25, 2010 at 5:15 AM
