1989 Lincoln Town Car STALLS WHILE DRIVING
150,000 MILES • V8 • 2WD • AUTOMATIC
EBUR382599
My 1989 Town Car 5.0 has begun to stall while driving down the road. I was on the interstate driving and the car just shut down, electrical and all. The only reason I knew it was that the radio went out. While still rolling, I put the car in neutral, started up and continued to drive. this happened 3 times within 1200 miles. After my 1200 mile trip, I took the car to the same dealer that works on it and they said that the problem duplicated but without a in-flight recorded they can't figure it out because it starts right back up and runs fine. I picked the car up and drove it home. Two miles to my house. The car cut off 3 times while driving, but I can alway shift back to neutral, start up and continue, but this is not safe because I loose steering and brakes. Can you help?
Mar 18, 2010 at 10:28 PM
MERLIN2021
  • 17,250 POSTS
Sounds like it could be your ignition switch, not the key cylinder, but the white plastic piece that the electrical harness plugs into.
Mar 19, 2010 at 3:59 AM
