1989 Lincoln Town Car how do you change a fuel pump relay s
1989 LINCOLN TOWN CAR
RICKYL3252
Engine Mechanical problem
1989 Lincoln Town Car V8 Two Wheel Drive Automatic
where is the fuel relay switch located on this vehicle
and how do i know if the fuel pump is bad
or if the relay switch is bad and how do i trouble shoot the relay switch in this vehicle
Nov 6, 2010 at 5:50 AM
JDL
  • 16,098 POSTS
Use a gage and check fuel pressure. My info says the fuel pump relay is under the hood, driverside fender lining. If you have an inertia switch should be in luggage compartment, driver side wheel well area.
https://images.2carpros.com/forum/automotive_pictures/170934_towncar_fuel_pump_relay_1.jpg
Nov 6, 2010 at 7:05 AM
