1988 Lincoln Town Car starter
GABOI912
Electrical problem
1988 Lincoln Town Car Automatic 66000 miles
k now i turned my key to start it n all i heard was a loud squell n also when i did that my engine didnt even budge, now is that the starter not catching or what?
Jul 24, 2008 at 6:17 PM
DJFINESSE80
  • 34 POSTS
STARTER IS WORKING, SOUNDS LIKE THE TEETH ON THE FLYWHEEL ARE WORN. 2 GET STARTED DISCONNECT BAT, RAISE CAR,CHOCK WHEELS,PUT IN NEUTRAL, TURN CRANK BY HAND, THEN START CAR, HAVE FLYWHEEL CHECKED OR REPLACED. SOMETIME A NEW STARTER WILL WORK AS LONG AS TEETH ON FLYWHEEL R NOT BROKEN, DONT USE SHIMS ON NEW STARTER UN LESS THEY
https://images.2carpros.com/forum/automotive_pictures/218559_m_bfac118db97d5095beff1f53f16e3594_6.jpg
ARE ALREADY ON, TAKE 1 SHIM OFF
Jul 29, 2008 at 9:38 PM
