[quote:81ee63a489="corvette4+3"][quote:81ee63a489="corvette4+3"][quote:81ee63a489="Rode Kil"]When I was driving my engine quit. When I tried to start it up it would fire then die. I can hear the fuel pump kick on I have replaced the coil. There is gas in it and I droped 6 more gallons to to make sure. so before I drop a ton more money into it does anybody have a clue?[/quote:81ee63a489]
first things first if you had your car on a lift for service the mech will turnoff your fuel supply which is located in the truck a white button press that to turn it on if that not the problem go to a lincoln dealer and tell them the problem [mech]usaually they will help you because i have one too and that what i do. i have replace many parts with there help so i don't want you to go in the wrong direction on this one then buy the part and have your local garage put it on .[ps don;t buy the dealer part there very pricey.GOOD LUCK[/quote:81ee63a489] one more thing i will tell you this inside your distributor shift thers another coil the whole shift comes out and you will see them like components replace those mechs have a special tool to remove them cost about fifty bucks to purchase the work cost could vary. :?[/quote:81ee63a489]
Rode Kil Here
The only time it was on a Hoist was for the exhaust which was over 6 months ago.
I will look into the second coil though thank you.
Sep 25, 2007 at 9:51 PM
