First things first if you had your car on a lift for service the mech will turnoff your fuel supply which is located in the truck a white button press that to turn it on if that not the problem go to a lincoln dealer and tell them the problem [mech]usaually they will help you because I have one too and that what I do. I have replace many parts with there help so I don't want you to go in the wrong direction on this one then buy the part and have your local garage put it on.[Ps don;t buy the dealer part there very pricey. GOOD LUCK[/quote:81ee63a489] one more thing I will tell you this inside your distributor shift thers another coil the whole shift comes out and you will see them like components replace those mechs have a special tool to remove them cost about fifty bucks to purchase the work cost could vary.?[/Quote:81ee63a489]
Rode Kil Here
The only time it was on a Hoist was for the exhaust which was over 6 months ago.
I will look into the second coil though thank you.
Wednesday, September 26th, 2007 AT 4:51 AM
