1987 Lincoln Town Car
DOITALLDUCAL420
  • 1987 LINCOLN TOWN CAR
  • V8
  • 47,000 MILES
My car windows only roll down when the ignition is turned back and my stereo don't work plus none of the gauges I so was curious what is the matter and what I need to fix it I am told it is the ignition but I don't know what part of the ignition it could be, all fuses are perfectlly fine all brand new what could be the problem?
Wednesday, March 25th, 2009 AT 8:31 PM
RACEFAN966
  • 5,029 POSTS
Ok first I need to know if you have a digital multi meter and if you are up to doing some tests? I will look up the wiring diagram and we will check the window switches and relays and the electical part of the ignition switch first. Get back to me and we will go from there.
Thursday, March 26th, 2009 AT 10:53 AM
DOITALLDUCAL420
I do not have any of that I just bought the car last summer it is in excellent shape and I stored it for the winter and when I just took it out all this stuff has gone wrong with it I had to change the battery and thats when it started doing it pretty much
Thursday, March 26th, 2009 AT 11:19 AM
RACEFAN966
  • 5,029 POSTS
OK but with out a digital multi meter and doing some tests I can tell you what is wrong as it would be a guess. It could be a circuit breaker the window, window switch or GEM Module or a relay in the circuit to many possibilities so testing would be needed to pin the problem down.
Friday, March 27th, 2009 AT 11:13 AM
DOITALLDUCAL
I figured it out it was the ignition switch you mechanics on here aren't too bright if ya ask me noone but 1 person guessed that out of 20 pages I put this on
Saturday, March 28th, 2009 AT 11:58 AM
