1986 Lincoln Town Car no injector pulse, fuel pump relay
DANIMAL43
I have a 1986 Lincoln Town Car 5.0L Limo with about 120,000 miles on it. I have good eninge cranking and good spark all the way to the plug. The fuel pump will not work unless I remove the pump relay and hot wire it, then I get about 41 psi at the test valve (engine not running). I also have no injector pulse, the red wires that go to the injectors have a good 12 volts to them, but when I use the noid light there is no flash (while engine cranking). I also disconnected the TPS and tried starting it, no go. If I shoot carb cleaner in the intake the enigine will fire off for about 1 second.
Nov 17, 2007 at 9:16 AM
MERLIN2021
  • 17,250 POSTS
Check your email, text will be hard to read if posted....Check your EEC relay, if it is bad, your fuel pump relay will get no power...
Nov 23, 2007 at 11:24 PM
