1985 Lincoln Town Car Heater core removal
AGCOALLIS2010
Heater problem
1985 Lincoln Town Car V8 Two Wheel Drive Automatic
I would like to know how to get to the heater core on a 1985 Lincoln Town Car
Jan 19, 2010 at 4:35 AM
  • 75,988 POSTS
REMOVAL Evaporator Case/Plenum Removal
https://images.2carpros.com/forum/automotive_pictures/12900_hc1_2.jpg
1. Remove the plenum assembly. See: Heater Core Case\Service and Repair Fig. 5 Typical heater core removal. 1982---88
https://images.2carpros.com/forum/automotive_pictures/12900_hc2_2.jpg
2. Remove the four retaining screws from the heater core cover and remove the cover from the plenum assembly. 3. Remove the retaining screw from the heater core inlet and outlet tube bracket. 4. Pull the heater core and seal assembly from the plenum assembly. INSTALLATION Fig. 5 Typical heater core removal. 1982---88
1. Carefully install the heater core and seal assembly into the plenum assembly. Visually check to make certain that core seal is properly positioned. 2. Install the inlet and outlet tube bracket retaining screw. 3. Position the heater core cover and install the four retaining screws and tighten. Evaporator Case/Plenum Removal
4. Install the plenum assembly.
Jan 19, 2010 at 6:39 PM
