If you are getting water in the back but not the front then the likely cause of this is the door seal or the sunroof. Do you have a sunroof?
If you do then we need to check the drain and make sure you are not getting water in the back from that drain. Just open the sunroof and pour water down the drain and make sure it is not making its way to the back seat. You are going to have a drain that goes to each corner of the vehicle so this could be the issue.
However, how much of the carpet is getting wet? Is it the size of a baseball or basketball, or larger?
When you say it is a puddle, is it standing water on top of the carpet or is the carpet and pad soaked as well?
Basically the best way to find this is to remove the carpet, close the vehicle, and run water on the vehicle until you see water come inside the vehicle. This will allow us to track down where it is coming from.
We just need to double check and make sure there is no water on the front floor as well. That could be a leaking evaporator that is soaking the rear carpet as well.
https://www.youtube.com/watch?v=q9_MZiS2_NE
I suspect this is not the issue but let's just make sure.
Aug 17, 2021 at 6:47 AM
