2002 Lincoln Navigator Regular Fuel Ping
LINCOLN
NMONTIGNY1
Is there an adjustment that can be made to my engine to accomplish the subject?
I have a 2002 Lincoln Navigator with a 5.4L 4V 300hp engine. Recommended fuel is premium, but I have been sussessfully using mid-grade fuel as recommended by the dealer who sole me the velhicle. I occasionally will add a half tank of regulasr fuel to the half tank of mid-grade with no noticeable adverse affect. On the one occasion I filled the tank with regular fuel, the engine pinged, so I never tried it again. The fuel in my area has 10% ethanol. The vehicle currently has 70600 miles on the odometer.
Thanks in advance for any response.
Oct 19, 2007 at 2:21 AM
BLACKOP555
  • 10,386 POSTS
there is a possiblility that the gas you tried when you got the ping had excess water in it or it was just BAD GAS. try it at a differnt gas station. if it continues you can buy some octane booster for 1-3 bucks per bottle and that should stop it still cheaper then paying the extra 30 cents per gallon.
Oct 19, 2007 at 2:45 AM
Suggested Repair
No engine adjustment was recommended. Try regular fuel from a different station in case the previous tank was bad or water-contaminated. If pinging continues, use an inexpensive octane booster.
Conversation Summary
The owner of a 2002 Lincoln Navigator 5.4L asked whether the engine can be adjusted to run on regular fuel instead of the recommended premium. Mid-grade has worked, but a full tank of regular caused pinging. The expert said the ping may have come from bad or water-contaminated fuel and suggested trying another station, then using octane booster if the pinging continues.
