98 lincoln
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the lighting fault diagnosed before driving. Give the technician the combination of failed lights and the owner's later identification of the turn-signal and hazard-switch assembly.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial guidance for obtaining diagnosis or clarifying the reported findings; they are not a verified repair procedure or an independently confirmed component diagnosis.
Discussion summary
98 lincoln
The owner of a 1998 Lincoln reported losing turn signals, brake lights and hazard flashers after a car wash.
Reported outcome: The owner later identified the turn-signal module in the steering column, including the hazard switch, as the problem.
The Lincoln model, diagnostic tests and completed replacement were not documented. Water damage was suggested by a reply but was not confirmed; restored light operation was not explicitly reported.
