1996 Other Lincoln Models starting
1996 LINCOLN
166,000 MILES • V8 • FWD • AUTOMATIC
HUGHJARDON
wont start but if i turn belt a little it does manually turn serpentine belt it wont move much but car starts after wards
Dec 26, 2007 at 1:53 PM
MERLIN2021
  • 17,250 POSTS
Turn a belt? Can you specify what belt and how you turn it?
Dec 26, 2007 at 1:56 PM
HUGHJARDON
manually turn serpentinebelt
Dec 26, 2007 at 2:18 PM
MERLIN2021
  • 17,250 POSTS
What happens before you turn the belt? does the relay click? Engine spin? Or nothing? Grinding sound?
And to turn the belt, are you using a wrench on the crank pulley? Put it in drive and roll a bit, then park and start it. I can only think maybe a dead spot or missing toothe or two on the flywheel?
Dec 27, 2007 at 12:51 AM
HUGHJARDON
merlin i sent you pm earlier, thx
Dec 30, 2007 at 3:57 PM
MERLIN2021
  • 17,250 POSTS
You can try that, it's the crankshaft position sensor.
Dec 30, 2007 at 6:54 PM
