1995 Other Lincoln Models KEY BROKE IN IGNITION
1995 LINCOLN
ANTOINETTEP
Transmission problem
1995 Other Lincoln Models V8 Automatic 202650 miles
SINCE I BROKE THE KEY IN THE IGNITION. I HAVE TO START IT BY PUSHING THE REST OF THE KEY INTO IGNITION TO START IT BUT THEN I STARTED TO HAVE PROBLEMS WITH TRANSMISSION. IT WOULD ONLY GO INTO 1st,sometimes2nd and reveres. Do you think it could be because the key is stuck? If so, who do i call to get the key out?
Nov 6, 2009 at 1:45 AM
HMAC300
  • 48,601 POSTS
any good lcksmith can or should have the tools to get teh key out then make a new one. It's cheaper if you take it to him for that. the transmission may be another problem though. check your fluid first and make sure the car runs right and take it to a trans shop to have them diagnose it
Jan 7, 2010 at 5:23 AM
