1976 Other Lincoln Models Ignition Switch
1976 LINCOLN
77,000 MILES • V8 • 2WD • AUTOMATIC
STOGIE2U
I believe I'm having a problem with the ignition switch in my Mark IV. I've traced the wires back through the SSI and the car will crank but won't start. Using a Chilton's manual I've tried all the tests and even was able to jump the wires from the harness to the ignition but the car still wouldn't start. How do I find and replace the ignition switch? I know it's somewhere near the firewall at the steering column. Thanks in advance for your help.
Apr 19, 2010 at 8:08 AM
HMAC300
  • 48,601 POSTS
it's under the dash near the bottom of the steering column. you'll probably have to remove a panel to get to it.
Jun 28, 2010 at 10:22 AM
