2006 Lincoln Navigator MISFIRING
68,450 MILES • V8 • 4WD • AUTOMATIC
GRIFFITH976
My 2006 Lincoln Navigator is misfiring; a week ago I accidentally put in approximately a 1/2 gallon of regular, upon realizing my mistake I immediately changed to the premium that I usually use. I'm sure that fuel has burned out by this point. At any rate,
I took the car for its 60,000 mile service, and had my spark plugs changed but the vehicle is still misfiring. Any suggestions?
Oct 31, 2009 at 12:47 AM
  • 75,988 POSTS
Hi riffith976 and TY for the donation
Following below will cause misfires:
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Oct 31, 2009 at 12:57 AM
