2004 Lincoln Navigator steering
2004 LINCOLN NAVIGATOR
123,000 MILES • V8 • 2WD • AUTOMATIC
WAZURRA1
  • 6 POSTS
When I go over bumps it feels like I may loose control of car. The wheel seems to be "chasing" when I go over bumps. I don't thinks it has shocks and struts since it has air suspension? Any help anyone??????????
thanks
Aug 10, 2009 at 8:25 AM
  • 110,241 POSTS
HAve you checked the steering components in the front end, especially the ball joints?
Aug 17, 2009 at 3:12 PM
WAZURRA1
  • 6 POSTS
thank-you. I had taken it to a shop prior to your response and that was exactly the problem. thnaks..
by the way do you think I should have the tires balanced after having thme replaced??
thanks agian
Aug 18, 2009 at 7:44 AM
  • 110,241 POSTS
Yes, whenever you replace tires, they will need balanced. Sorry about the time it took for a response. THere are so many to answer. Regardless, thanks for using 2carpros.com and let us know if you have questions in the future.
Also, if you add to this thread, it will show up in my email and I'll get back to you much quicker.
Aug 18, 2009 at 3:27 PM
WAZURRA1
  • 6 POSTS
thanks again for your correct response! Actually I had tires balanced the the ball joints replaced should I again have the car balanced? I feel a slight shimmy around 70-74. with toyo tires instead of my mich.
thanks
Aug 20, 2009 at 12:54 AM
  • 110,241 POSTS
THis may sound funny, but do you feel the vibration in the steering or the seat?
Aug 20, 2009 at 1:48 PM
WAZURRA1
  • 6 POSTS
only in the steering so I assume it has something to do with the front. As I mentioned I had the ball joints replaced which made it run ALOT better but I still feel a slight vibration not all the time but around 70-75? Could any other part possibly be worn out? I have only 123,000 miles
thanks
Aug 20, 2009 at 10:54 PM
  • 110,241 POSTS
Chances are it is either tire balance or alignment. If you feel it in the steering, you're right. It's coming from the front tires. When you feel it in the seat, it's the rear. Did you have it aligned when the work was done or the tires balanced?
Aug 21, 2009 at 2:12 PM
