2004 Lincoln Navigator Low Oil Pressure Light
87,000 MILES • V8 • 2WD • AUTOMATIC
SAMAMOUR
When vehicle is first started in the mornings, there is a small rattling noise which disappears after engine is warmed and no longer is heard unless the vehicle sits off for longer than maybe 2 hours. However, today the low oil pressure light came on shortly and we are getting concerned.
Jan 16, 2010 at 2:11 PM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings
Jan 16, 2010 at 2:26 PM
SAMAMOUR
[quote:32fe3c020b="rasmataz671"]Check the oil pressure with a mechanical gauge if normal replace the oil pressure switch abnormal could mean oil pump and engine bearings[/quote:32fe3c020b]
Oil pump or engine bearings...are these expensive repairs? Should I drive the vehicle to the repair shop or have it towed. We just purchased the used vehicle and had the oil changed immediately and just had the compressor replaced on the front suspension.
Jan 16, 2010 at 3:58 PM
  • 75,988 POSTS
This rattling noises does it sound more like a ticking/tapping noise is it coming from the upper end of the engine if so could be lifter/valve problems.
Jan 16, 2010 at 4:26 PM
SAMAMOUR
[quote:e0d9da50fe="rasmataz671"]This rattling noises does it sound more like a ticking/tapping noise is it coming from the upper end of the engine if so could be lifter/valve problems.[/quote:e0d9da50fe]
The sound is a LOUD tapping and lasts for about 2 to 3 secs. I thought that it may have been the fuel grade that I put in it which was 87 instead of the 93 which I will put in from this point forward. And yes the noise seems to be coming from the upper end of the engine. I want to get it to the dealership first thing Monday...can you offer any suggested terms I should use to explain what the concern may be? Also note that the engine seems to run like a champ.
Thanks a ton for your input..
Jan 17, 2010 at 7:40 AM
  • 75,988 POSTS
Sounds more like a lifter leakdown problem-
Jan 17, 2010 at 7:49 AM
SAMAMOUR
[quote:f731ba716b="rasmataz671"]Sounds more like a lifter leakdown problem-[/quote:f731ba716b]
What exactly is that and what would it stem from? I just had the Compressor for the suspension replaced on friday morning..Would it stem from that activity?
Jan 17, 2010 at 7:58 AM
