2003 Lincoln Navigator rear disk brakes
41,000 MILES • V8 • 4WD • AUTOMATIC
MIDDLESBORO
how do the rear brake disk come off.
i have the cal. & cal. bracket off and the 4-bolts off the back. but something is holding it on.
Dec 17, 2009 at 8:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you have removed the anchor and caliper assembly then remove the press-on keep nuts from the hub studs (if equipped). once this is done it is ready to come off. if it feels stuck then its because of the brake heat overtime will get it stuck. bang on the rotor with a rubber mallet to loosen it and jar it off.
Dec 17, 2009 at 9:05 AM
