2001 Lincoln Navigator O2 sensor replacement
112,000 MILES • V8 • 4WD • AUTOMATIC
JNICK
is this a difficult replacement? Is it problematic and should be left to professionals? Would appreciate some tips before I purchase repair manuals and parts. Not happy with estimate received.
Nov 18, 2009 at 12:31 PM
OBXAUTOMEDIC
  • 3,720 POSTS
O2 Sensors are pretty easy in most cases to replace. Some harder ones are just do to the location. There is a special tool for removing them. You will also need to know which one needs replacing. On most V8 engines there are 4 O2 Sensors. And getting codes pulled will help determine which one. If don't have codes you can go by your local parts store and have them pull them for you then post here.
Nov 18, 2009 at 12:38 PM
