2001 Lincoln Navigator 4X4 STUCK IN 4 high
2001 LINCOLN NAVIGATOR
129,000 MILES • V8 • 4WD • AUTOMATIC
DENY0324
  • 6 POSTS
last week i turned the knob while driving about 30 mph from a4wd to 4h then to 4l and now the dash indicator shows whichever position the knob is in but the vehicle wont disengage from 4h. i heard a loud thud when this was intiitially done. did i tear up the motor/gear that engages/disengages the 4 wheel drive?
Dec 19, 2007 at 11:30 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely, they were kind of a problem to begin with. In the future, you should NEVER try for 4lo when moving.
Dec 20, 2007 at 8:00 AM
DENY0324
  • 6 POSTS
[quote:c924288263="2CarPro Jack"]Most likely, they were kind of a problem to begin with. In the future, you should NEVER try for 4lo when moving.[/quote:c924288263]
How can I fix the problem..what I do..with out taking to the dealer...can you show me..thanks so much
Dec 20, 2007 at 8:17 AM
2CARPRO JACK
  • 11,533 POSTS
Looks like you just remove the 4 bolts holding it and pull it off. Reverse for install
Dec 20, 2007 at 8:32 AM
DENY0324
  • 6 POSTS
[quote:503ce89a88="2CarPro Jack"]Looks like you just remove the 4 bolts holding it and pull it off. Reverse for install[/quote:503ce89a88]
Hi my husband took the it off and the motor it works ok..put it back and it still stuck like it is still in 4x4 high.. I am having a hard time turning the wheel when I turn into parking space..is there anything else he can do.
thanks
Denise
Dec 20, 2007 at 12:56 PM
2CARPRO JACK
  • 11,533 POSTS
Have the powertrain scanned for codes, Autozone will do it for free.
Dec 20, 2007 at 11:46 PM
DENY0324
  • 6 POSTS
Will it be safe to drive there to autozone..in general safe to drive at all?
thank you so much!
Dec 21, 2007 at 11:48 PM
2CARPRO JACK
  • 11,533 POSTS
Not really good for it, but need to see if it has any codes
Dec 22, 2007 at 3:20 AM
DENY0324
  • 6 POSTS
Hi I took it to Autozone like you said and they read no codes..What to check next before taking it to the shop. Please more ideals?
thanks
Denise
Dec 23, 2007 at 12:13 AM
DENY0324
  • 6 POSTS
took in to ford dealer they replace the clip and plastic cam and after 600.00 later and almost a week...we got it back..still drives like it is in stuck still in 4 high. do you think they didn't fix it.
It still turns like it is in 4 high. very stiff and makes a grinding noise when I turn and turn in parking spaces too
Jan 2, 2008 at 1:41 AM
ROBERT THOMAS EACHUS
1st no you didn't tear up the shift motor.
2nd failing to shift out of 4x4 may have gotten your truck to give up trying to get it out of 4x4, disconnect battery to reset.
3rd 4x4 Low shouldn't engage while moving or in drive if I remember correctly.
4th 4x4 can get stuck especially on dry asphalt. Drive in a strait line for a short distance on a flat surface. (Sand or gravel is best) shift to N take your foot off the break let the truck settle break R let it engage then go back to N flip the 4x4 Sw back to AWD/2WD give it 20 seconds to disengage. If that doesn't do it disconnect the battery start it back up sw to n and give it another 20 seconds. If you were on pavement try again or find some sand... the problem is that resistance you feel cornering makes it hard for it to disengage and the computer will give up to avoid burning up the shift motor. If this doesn't work on sand after 2 tries your probably looking at a mechanical or electrical issues not just stuck.
Nov 16, 2019 at 4:51 PM
