1999 Lincoln Navigator miss fire at idle
DAVE KEELING
Engine Performance problem
1999 Lincoln Navigator V8 Four Wheel Drive Automatic
engine miss fire at tick over on gas switch to lpg
engine runs smoth have ijector signels and new ijectors as we found No 3 not ticking and showing open loop on scan when in take manifold was off and pipe work out the way we changed plugs so we have 8 new plugs
feed back info on lincon town car heater all good and working ok thans Dave Keeling
Sep 17, 2008 at 6:06 AM
2CARPRO JACK
  • 11,533 POSTS
A little cryptic... misfire at idle? WIth scanner on it does waveform look good for all injectors? try ignition check as well, may have a weak/bad coil have seen them as well as injectors go bad on those engines
Sep 17, 2008 at 7:09 AM
