1998 Lincoln Navigator stuttering
1998 LINCOLN NAVIGATOR
185,000 MILES • V8 • 4WD • AUTOMATIC
THEKANDYCHIC
my truck was running fine today. the gas got really low down to 5 miles to empty...it starting stuttering a little when i got close to the gas station i filled it all the way up....on my way home i noticed that my speed odometer wasnt working....then i went down the road and it almost stalled out...when i press the pedal it idles really high before going into gear i was able to coast back home but it stutters when i try to accelerate...
Jul 6, 2008 at 1:29 PM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
If it won't make it to Autozone, buy a cheap scanner, they can be had for 30-40 dollars, a good investment, since they cover all cars sold in the USA from 96 on...
If the light is blinking, it means possible damage to the converter...service it right away! Your truck by the description you gave has a VSS problem and the check engine light should be on.
Jul 6, 2008 at 1:37 PM
