1998 Lincoln Navigator COP Spark Plug Replacement
B.KIRSCH
Engine Mechanical problem
1998 Lincoln Navigator V8 Four Wheel Drive Automatic
Ok I know I'm dragging this out, but I've been reading that it's easier to repalce the plugs if you remove the fuel rails. Is this true? If so, how tough is that and what are the cautions? Any help is greatly appreciated.
Jun 5, 2008 at 6:23 AM
MERLIN2021
  • 17,250 POSTS
Ford has flexible boots on the COP's DO NOT remove the fuel rail, undue the screw on the COP, twist and pull, it clears the rails EASILY!
Jun 5, 2008 at 8:03 AM
