1998 Lincoln Navigator Coil-On-Plug Ignition
1998 LINCOLN NAVIGATOR
114,000 MILES • V8 • 4WD • AUTOMATIC
B.KIRSCH
I would like to know if I should replace the sparkpugs due to the mileage. it runs fine, but I think after 100000 mi, it needs to be done. I'm assuming that I can just remove the coil over the plug and the I can access the plug and remove and replace? Any info would be greatly appreciated.
Bob
May 16, 2008 at 5:17 AM
MASTERTECHTIM
  • 4,750 POSTS
yes definitely replace the plugs. this is the point where if you dont replace them the coils are going to burn out.
May 16, 2008 at 9:44 AM
BLACKOP555
  • 10,386 POSTS
coils will come right off and then you will have acess to the plug.
May 16, 2008 at 12:07 PM
