98 lincoln mark viii
KMWSEW1992
have 98 lincoln mark viii 32 vavle lots amiles and have replaced thermostat radiatior water pump and it still trys to run hot but cant find any leaks anywhere
Sep 3, 2007 at 1:53 AM
MERLIN2021
  • 17,250 POSTS
Are you loosing anti-freeze? If not I have seen the impellers on the water pump corrode to the point there arent any left! Have a llok in the recovery tank to see if water is circulating! If all else fails have a pressure test done, may have a small leak in a freeze plug....
Sep 3, 2007 at 4:17 AM
LEGITIMATE007
  • 5,121 POSTS
check your engine coolant temperature sensor *ect* also. the computer needs to know the temperature of the engine so that it may turn the fans on accordingly
Dec 14, 2007 at 2:35 AM
