1998 Lincoln Mark VIII Trouble codes and not heat
147,000 MILES • V8 • 2WD • AUTOMATIC
MADKINSON
Following procedure, the HVAC control gives a "25" and "155" code. I know the "25" is for the blend door, but need help with the "155". I know the actuator is bad, but when I manually move the lever on the blend door itself, the air never gets hot, only cool to luke warm. Any help is appreciated.
Dec 5, 2009 at 10:46 PM
BMRFIXIT
  • 19,053 POSTS
If opening the blend door and have no heat, is the engine reaching operating temp and if not check thermostat
if its reaching the operating temp
check heater hoses both should be hot if one hot one warm heater core need to be isolated and flush
Sorry I cant find the codes you supplied lets make sure we are at the same page try to get the codes this way or by using a scanner tool
Ensure coolant temperature is at least 120°F (49°C) before entering self-diagnostics.
Turn ignition to run position (engine off).
Simultaneously depress OFF and FLOOR buttons on EATC module, then press AUTOMATIC button within 2 seconds.
Display will show a pulse tracer going around the center of the display window for up to 30 seconds while test is running.
SELF-DIAGNOSTIC TEST CODE DIRECTORY
Self-Test & (Intermittent) Fault (Run Time Code) (1) NGS Tester (DTC) Code (2) Problem/Description Test
024 (022) B1249Blend Door Actuator Short
024 (025) B1249Blend Door Actuator Failure
031 (*****) B1251In-Car Temp. Sensor Open
030 (*****) B1253In-Car Temp. Sensor Short
041 (043) B1255Ambient Air Temp. Sensor Open
040 (042) B1257Ambient Air Temp. Sensor Short B1257
050 (052) B1261Sunload Temp. Sensor Short B1261
***** (*****)U1041Vehicle Speed Signal
***** (*****)U1073Engine Coolant Temp. Signal
***** (*****)U1222Interior Lamp Signal
***** (*****)U1235Display Data Signal
Dec 5, 2009 at 11:06 PM
MADKINSON
Thanks, Jack O for a quick reply! The display flashes a "25" and then a "155". I double checked. Also, the actuator is not even hooked the the blend door any longer. Both heater hoses feel hot, but the car seems to take an abnormally long time to reach operating temp. I'm just trying to get a little heat until I can replace the actuator as its int he teens here in OK. Thank
Dec 5, 2009 at 11:13 PM
BMRFIXIT
  • 19,053 POSTS
If its taking long time to reach operating temp
should have the thermostat checked or replaced
as the engine coolant should be hot for it to provide heat on the inside of the car
blend door only allow the air to channel between the heater and AC and since you are able to move it
Dec 5, 2009 at 11:32 PM
