1998 Lincoln Mark VIII tail light (attached at trunk) not w
REGINALD LAVILLA
Electrical problem
1998 Lincoln Mark VIII V8 Two Wheel Drive Automatic 114K miles
I would like to get it operable again. have no idea how to "tackle" the problem.
Feb 9, 2010 at 4:18 AM
JDL
  • 16,098 POSTS
Hi, thanks for the donation. The green wire is voltage for brake lite, brown wire for tail lamp, trunk lid. Black is ground. I'd use a testlite check for voltage on brown wire. Should go hot wnhen you turn on lite switch.
https://images.2carpros.com/forum/automotive_pictures/170934_lincoln_2.jpg
Feb 9, 2010 at 8:15 AM
