1998 Lincoln Mark VIII HOT AIR FROM A/C DUCTS
1998 LINCOLN MARK VIII
JAMES WALDREP
Air Conditioning problem
1998 Lincoln Mark VIII V8 Two Wheel Drive Automatic 104K miles
Regardless of control button pushed, hot air comes out the A/C ducts. Is this a vacuum motor failure for the heater door? If so, where is this vacuum motor located? Can a DIY guy like me get to it? Thanks, James
Feb 7, 2008 at 2:25 AM
POOLBOY
  • 5 POSTS
Have you found any solution to this problem? I have the same problem.
I have an estimate from the dealer for $700, and my local AC Shop says that this is a "common" problem!?
Sep 20, 2008 at 1:11 PM
POOLBOY
  • 5 POSTS
I know that it is too late to help you with your problem, but perhaps to others who are googling this problem they may check out the complete dialog in my posting : 1998 Lincoln Mark VIII Mass Air door Air conditioner blows THIS IS THE THE CHEAP DESIGN FLAW THAT WILL COST $800 TO REPAIR:
https://images.2carpros.com/forum/automotive_pictures/244859_shaft_fracture_1.jpg
Sep 21, 2008 at 11:57 AM
