1998 Lincoln Mark VIII bumping noise!!!!!
146,000 MILES • V8 • 2WD • AUTOMATIC
AC1989
hi i have a 1998 lincoln mark viii lsc with 146k miles....it has a loud bumping noise when im driving above 15mph on the front passenger wheel area ive checked the strut/coil spring,the brakes and brake rotor,and the wheel bearing and all checked out good......what could be the problem
Oct 5, 2009 at 7:55 AM
DESHAWN93
  • 5 POSTS
I am not sure if you are still having this problem but i have the same with my rear, it sounds like the air bags are not absorbing or pumping like they should, im order to absorb the pressure of bumps.
Apr 29, 2010 at 10:27 AM
