1998 Lincoln Mark VIII air ride
1998 LINCOLN MARK VIII
BIGGER
Suspension problem
1998 Lincoln Mark VIII V8 Two Wheel Drive Automatic
i installed both rear air struts and selanoids also replaced the air pump relay. the air bags hold air parked but when you drive it the front drops. can bring it home turn the key off and back on the pump comes on the car rises and will stay there untill you drive it then the front drops. please help.
Apr 13, 2009 at 6:16 PM
BLUECOLLAR
  • 86 POSTS
The Mark VIII drops slightly at hwy speeds. While at that lower height, it is exposing cracks in the fold of the rubber air bladder. This page should explain a little better:
Jul 26, 2009 at 6:01 PM
