1998 Lincoln Mark VIII
1998 LINCOLN MARK VIII
KEVINSCRUGGS
Engine Performance problem
1998 Lincoln Mark VIII V8 Four Wheel Drive Automatic
car will not start at all but will turn over
May 29, 2010 at 10:20 AM
Lets do below for a start to determine if its fuel or spark related issue and get back asap.
Cranks but no start:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 29, 2010 at 7:13 PM
