1997 Lincoln Mark VIII Start
1997 LINCOLN MARK VIII
114,000 MILES • V8 • 2WD • AUTOMATIC
CCLEMENTS
I have an interminent starting problem.Fuel is present at the rail. The fuel filter was plugged but I changed it. At this moment it won't start ... but over the past few months the problem would come and go. I'm thinking crank sensor ... any ideas? One more thing I did was have the computer reprogrammed at the dealer a few months ago.
Dec 6, 2009 at 2:10 PM
Do below and tell me what's missing or not right
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard
Dec 6, 2009 at 2:24 PM
