1997 Lincoln Mark VIII front airbags
1997 LINCOLN MARK VIII
BRADF
Suspension problem
1997 Lincoln Mark VIII V8 Two Wheel Drive Automatic 139k miles
similar to many owners of Mark 8s, mine is loosing lift up front overnight, but does inflate when started and holds during normal driving. I'm wondering what the most common cause is. Could it be o-ring seals at the pump? This seemed to be what happened in my 1984 Continental. How can I troubleshoot? Thanks for your help!
Jul 5, 2009 at 3:33 AM
BLUECOLLAR
  • 86 POSTS
If the solenoids haven't been removed before, they won't be the culprit. Hate to be the bearer of bad news, but the front air struts need replacing. To prove my point, try this test:
Now is a good time to figure out whether to stay with the air or to convert to coil springs.
Jul 26, 2009 at 10:54 AM
