The problem is because of the leak. You can go to the dealer and spend $1,500+, go to an aftermarket company for the air suspension parts -OR- do a coil conversion on the vehicle. Doing the coil conversion WILL BE cheaper in the long run for sure. It is recommended to do all 4 wheels to keep from having problems, but if money is tight, you could just do the rear conversion to get you by for awhile.
SPONSORED LINKS
Sunday, February 6th, 2011 AT 6:40 PM
