1997 Lincoln Mark VIII #6 Hole Misfiring
1997 LINCOLN MARK VIII
86,000 MILES • V8 • FWD • AUTOMATIC
PLJONES
Hi. My car is intermittently misfiring on the #6 cylinder. I have changed the spark plugs, #6 coil pack and fuel injector with the same results, it still misfires. I've ran the codes on it and it still says it's #6. I assume its in the wiring harness or computer now. Are there any known problems with this and where should I start looking if it is in the harness?
Oct 23, 2010 at 10:32 AM
Check cylinder no.6 compression
Oct 23, 2010 at 10:37 AM
PLJONES
My compression is good but still have the problem. Also, I tested #6 coil pack lead with a tester and detected a misfire in the coil pack lead. Is there a common place that these wires rub that I can check? When it is running on all 8 it runs really strong. Thanks for the quick reply
Oct 23, 2010 at 10:41 AM
Could be the crankshaft position sensor causing the misfire at 6-check and test or the computer
Oct 23, 2010 at 12:53 PM
