1996 Lincoln Mark VIII no blinkers or flashers.
1996 LINCOLN MARK VIII
MUNOZMARTIN76
Electrical problem
1996 Lincoln Mark VIII V8 Two Wheel Drive Automatic
I have a 96 lincoln mark VIII and the blinkers along with flashers are not working, also the check engine light is on, plus it feels like it has a little miss to it @ idle and driving.
Oct 6, 2010 at 2:48 PM
MADMIKE1735
  • 951 POSTS
as far as the check engine light goes, bring it to your local parts dealer, they should be able to scan it for free.... let us know the code, or codes you get.... as far as the blinkers not working, that maybe a fuse that is blown... can also be a bad flasher... let us know what you find.
Oct 6, 2010 at 2:52 PM
MUNOZMARTIN76
I will take it to my local dealer, and i will check the fuses and flasher. I will let you know a.s.a.p.
Oct 10, 2010 at 8:07 AM
