1996 Lincoln Mark VIII Missing
1996 LINCOLN MARK VIII
67,732 MILES • V8 • 2WD • AUTOMATIC
CLARKT69
Background: I just bought this car.
The engine doesn't run smoothly, (or as smoothly as it should) especially at start up, it gets a little better after it warms up. I was going to replace the wires, but they are expensive and I want to make sure I'm not wasting my money.
Feb 21, 2010 at 11:07 AM
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 22, 2010 at 4:11 AM
