1995 Lincoln Mark VIII cooling fan
129,000 MILES • V8 • 2WD • AUTOMATIC
JRS0589
My cooling fan will not work properly I have tried the following to no avail. Found two sensors on the manifold one for the gauge its fine then another on
oppisite side of manifold it didnt kick the fan on when crossed. then changed the brain box in front
of the raidiator. is there another sensor ? going to test fan motor today. fuse is good 40 amp.
Dec 1, 2007 at 11:27 PM
BLACKOP555
  • 10,386 POSTS
there is a relay youshould check for voltage at the fan if you have none then work your way back to the brain. if you have voltage then the motors are bad.
Dec 2, 2007 at 1:22 AM
  • 75,988 POSTS
jrs0589
I've answered your question you said it comes On when you hot wired it-what's going on here.
Go back find your other post read it and stay in this post with B5
Dec 3, 2007 at 3:38 PM
