1995 Lincoln Mark VIII Air ride suspension problem
264,000 MILES • V8 • 2WD • AUTOMATIC
HALERAISER74
I have a 95 Mark VIII, after you drive the car for 5 min. or so the check air ride system light comes on and air ride eventually goes down from driving the car. If i turn the car off for a few minutes and restart or just turn the ignition on the air compressor comes on and airs the suspension back up and then the same thing happens again. It doesn't leak down over night. Has anyone come across this problem before and can point me in the right direction. I don't want to throw money and replace parts that don't need replacing. Any suggestions would be greatly appreciated.
Aug 8, 2008 at 9:47 AM
MERLIN2021
  • 17,250 POSTS
The system has stored a trouble code, and step one is to have a shop that can read the codes do so..this will eliminate replacing the wrong parts..
Aug 8, 2008 at 10:04 AM
MERLIN2021
  • 17,250 POSTS
Air ride is more expensive and does keep your ride level even with a few extra passengers, springs sag over time too, and don't level the ride as well.
Jul 22, 2010 at 5:53 AM
BLUECOLLAR
  • 86 POSTS
The easiest and probably the cheapest thing to do is the coil spring conversion, but if you want to keep the air suspension, your going to need to replace the front air struts. One important thing you said was....after the check suspension message came on, it went down. The way this system is designed, if the check suspension message comes on, no air should come in or out of the struts/springs. If the car goes down after the message comes on, YOU HAVE A LEAK.
Keep in mind that the easiest thing an air suspension system can do is to sit still. The hardest thing is to be driven with no help from the compressor.
Jul 25, 2010 at 1:10 PM
MERLIN2021
  • 17,250 POSTS
Good to see you still out there Ed!
Jul 26, 2010 at 7:25 AM
MERLIN2021
  • 17,250 POSTS
Will do!
Aug 20, 2010 at 1:29 AM
