Steering problem
1993 Lincoln Mark VIII V8 Two Wheel Drive Automatic
I replaced high pressure powerstering line onthis lincoln,my problem is I have powerstering to right,but when I try turn to left it's very hard to turn! my question is this! is there air in the line,or is rack&pinion bad and need to be replaced,if not, how do bleed the rack&pinon to get the air out of unit. I would gladlee dontate to your tech,s. Ijust want make sure this not some sort of scam,before I donate. thank you! gary.
Aug 30, 2010 at 5:16 AM
