1994 Lincoln Mark VII
1994 LINCOLN MARK VII
BENM2
Transmission problem
1994 Lincoln Mark VII V8 Front Wheel Drive Automatic 125.00 miles
IT'S A MARK 8 ND FOR SOME REASON WHEN I PRESS ON DA GAS PATTLE IT WONT GO PASS 35 MPH THERE IS GAS DA GAUGE'S WONT MOVE PASS 35MPH HELP PLZ DA OVER DRIVE IS NOT ON
Mar 26, 2010 at 11:20 AM
Lack of acceleration,chugging,hesitating,bogging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 26, 2010 at 11:38 AM
