1991 Lincoln Mark VII won't ingage starter
NEVRGONASTOP1T
Electrical problem
1991 Lincoln Mark VII Two Wheel Drive Automatic 74000 miles
I have put a start'silnoid relay on iy and it still just clicks. the battery is fully charged I can not figure this out could you please help me with this problem
Apr 10, 2010 at 11:07 AM
  • 75,988 POSTS
Can you engage the starter by shorting out the relay If so test the transmission range switch and ignition switch.
Apr 11, 2010 at 1:56 AM
BOWNAXE
  • 5 POSTS
Have the same problem...replaced starter relay on fender, same results, no crank. Towing home to get at starter.
Mar 12, 2011 at 2:23 PM
