1991 Lincoln Mark VII Horn signal problem
1991 LINCOLN MARK VII
89,000 MILES • V8 • 2WD • AUTOMATIC
PHILIP1711
The horn stooped working. i changed the fuse it not help. What to do to fix the problem?
Thanks
Philip
May 5, 2010 at 8:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check out the horn relay and horn pad switch as well as wiring to the horn. if all is good then horn itself may need replaced.
May 5, 2010 at 11:28 AM
