1991 Lincoln Mark VII Battery Not Chargeing
1991 LINCOLN MARK VII
73,820 MILES • V8 • 2WD • AUTOMATIC
PHC2830
Have a 1991 Mark VII LSC. Have replace battery, ECM and Alternator. When the engine is running still only show voltage of battery.
From what I have found should show around 14-15 Volts if system is charging correctly.
What do I need to check.
Thanks
Mar 8, 2009 at 11:07 PM
STREAKKER
Replace the voltage regulator mounted on the passenger side fender. It is a cheap part and will probably fix the problem. These cars have external regulators.
Jul 11, 2009 at 12:30 PM
